HEAD LIGHT ADJUSTMENT?
jsaga
:sly :sly:sly DOES ANYONE NO HOW TO LOWER THE HEAD LIGHT ON A 2002 F 250 ?:doh: .WITH MY 5.5 LIFT IM BLINDING ALL.::sly :sly :sly
dont know if they are the same as the 04, like mine. but there are two "allen, or star" type screws that adjust both up & down, and side to side.
on my truck, they are very obvious to see.
your owner's manual should have some info i believe.
and yes, your all caps are blinding us as well. :roflmao :roflmao :roflmao
The inner set screw adjusts the beam up/down and the outer set screw dials the side to side(or vice versa)
You can use a 7mm nutdriver(the easiest) a 9/32 socket with 1/4" driver or a T-20 Torx bit.
Here's a few photos I shot on the set screw locations,just as a note this was off my 2002 Excursion.:sweet
:welcome3 to the SuperDutyDiesel community if I haven't already welcomed ya'll :thumbs
jsaga
Thanks
:sly I tried twice @ night,did not see rear adjustment torx screw .painless job thanks.I Had to bring it all the way down,All OK now.:sly
RSG
Savoy IL
Are there any instructions on where to focus the beams when readjusting?
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I just use the garage door as a target. I alternately cover each headlight with a blanket or tarp and adjust each one individually until the spacing and height looks about right. Then after I drive at night a few times, I adjust them up or down as I want until I got them right where I like them. :thumbs :thumbs
It's a lot easier to do than you'd think.
