Grille removal 01 F350
rammertide07
Rogersvilles, AL
Ok..I know it has something to do with the four screws at the top (done got them out) and the four clips between the top of the bumper and bottom of the grille. Question is: are you suppose to pry the clips down or push them up? I HATE CLIPS:rant I feel like I'm going to break something....why cant they just use screws. Guess they figured it would be too darn easy that way. Thanks
wpfd571
White Pigeon Mi.
You push the little tabs on the clips up. Just start on one side and work your way to the other it should pop right out, its real easy after ya figure out how to do it
rammertide07
Rogersvilles, AL
GOT IT:D figured out I was suppose to be going a little lower on the clip. I'll pos pics for future refference for ppl with thte same problem. Now I'm checking out this llittle bitty hole for the air intake. Also been looking to see if I could run a second filter down past the aletenator below the truck somewhat
THANK YOU!!!:hail
