94f450sd
certified nutjob
got it yesterday.now i need to get the truck running again to try it out.it has the new coupler on it.the spacer block is internally modified to allow the use of 2 IPRs wich i will be running.i cant see where it was modified so it must be a small modification that i just cant see.and it came with a new bolt design to hold the sytem to the cover.much better bolts than it used to have.
