Glow plug replacement
Glassdude
Sonoma, CA
I'm replacing the UVC harnesses glow plugs and valvew cover gaskets. Do I need to worry about the small amount of oil that gets into the cylinder before installing the new glow plugs?
Just make sure the oil does not flow into the glow plug hole. Use a rag to mop it up if you have a small puddle.
Dave :)
Tman123
That One Guy
Murray, Utah
Are glow plugs all that hard to change? And with replacing them do I also need to replace any gaskets?
Travis
Pm_guru
