Gear Shift Lever Disassembly
Tbar
SDD STAFF/Moderator
Can anyone give me the disassembly instructions for the gear shift lever on the column.
I found the broken wire that is preventing the OD lock out button from working but I can't get to it without disassembing the lever from the column.
Tbar
Bob G
SW Michigan
Remove the plastic cover around the steering column. Remove the pin that holds the lever in. It's been awhile since I replaced mine but it's not to hard to do.
Bob
dserge66
