fuel tank delamination
Ford_Forgotton
Oddd, I thought they were all plastic tanks. My 2000 F-350 is.
You sure its not the skid plate rusting?
Is this on the inside of the tank, or the outside?
anchorsafe
Warren, MI
Metal tank, went to dealer to inspect. Truck has 65,000 miles, kept in doors. Rust inside of tank, 40 gallon between the frame, rear of truck. Rust thru out the fuel system. Fuel bowl full of rust. Ford seems to know about the problem. We took vehicle in for power loss at highway speeds (injector failure how everybody describes) instead they found rust. Makes you wonder how many other people have this problem.
anchorsafe , Glad to have you hear. Please post where you are from and a picture of your truck if you can. Come back often.:thumbs
gotta be a venting issue...water/moisture being trapped in the tank
and not able to evaporate id say...
Brad1103
