Here in Alaska all the trucking companies are having some major performance and fuel mileage issues with Cat engines. The company I work for got together with Caterpillar and did some extensive testing on a dyno with Seattle fuel and Alaska fuel. With a 500 hp C15 Cat on the dyno they got 50hp more on the Seattle fuel than they did with the Alaska fuel. They also tested a 565 ISX Cummins engine and found a loss of about 5hp with the Seattle fuel if that makes any sense. Several weeks ago we started shipping fuel from Seattle to the local terminal and the fuel mileage increases have shown up already with the Cat engines. The drivers are also much happier with the extra power it makes. I personally run a Cummins ISX and tried the Seattle fuel and found that I lost some power and about .5 mpg so I have went back to using Alaska fuel. Cat has admitted that these results show that they have some problems with there fuel mapping and are working to fix the problem. Prior to this testing they were not willing to do a thing. They also sent the Alaska fuel in for some lab tests and the testing firm found it to be the worst fuel they had ever tested.
This testing has got me to thinking about what we put in our trucks. Have you guys noticed any power/mileage differences depending on what refinery your fuel comes out of? My mileage has always been low compared to what some guys say they get.. This bad Alaska fuel may be why I can only get 16mpg on a good day when some claim 20mpg. I normally only run 14-15mpg empty and 10 or less when loaded down(16k).
