Thanks for all the info and diagrams for this job (fuel pump replacement) but I just got the bowl out and I found a sand pit at the bottom. I was astonished at the amount of junk that came out and is still in there. It is soaking in engine degreaser as I type this. Is that going to hurt anything? Suggestions on cleaning it out? It is completely gutted, senosors, "base plate" and all. The base plate is pretty thin in some areas, it also has 5 95 stamped on it, is this the month my truck was made? Can I call an auto parts store or is this a dealer only thing? Do I need to worry about it?
Also there is a black plasctic cone shaped item that sits on the drivers side of the fuel bowl. Is that the FPR screen? haven't messed with it yet, also there is a thick bluish green hose that runs from the part that bolts on the driver side of the fuel bowl to the bottom of the fuel bowl. Is that a special type of hose? I would like to replace it while everything is off.
Appreciate the help!
Craig
Craig
