front unit bearing conversion
Bags
Crowd Pleaser
Frostproof, FL
Does anyone know of another front unit bearing conversion kit other than Dynatrac? The price of that kit is not very enticing. I know it is very high quality stuff, but I would like to see what else is out there before I buy. Anyone else heard of anything? Anyone ever fixed it themselves?
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I haven't heard of any alternatives to the Dynatrac as far as conversion kits are concerned.
FWIW, I did the Dynatrac thing last Labor Day. I started a thread here detailing the adventure. If you look up my previous posts, you can go right to it.
I also did a some pics as I did the Dynatrac conversion and can be seen in my webshots, link is below.
Bags
Crowd Pleaser
Frostproof, FL
Anyone know if the newer unit bearings can be adapted to the older axles. I know they are a different design, but still the same sealed unit bearing. Suppose to last longer. With these wide wheels I have, I replace one about every 30,000 miles. Guess I have no choice but to go to Dynatrac.
Frankenstien
Frankestien
South Prairie Wa.
Under the FWIW catagorie....
Since about the 40 k mark.. now at 150K.. every summer I pull my bearing units out, using the syring that come with some of those ink cartridge fill kits I force in fresh Mobile 1 Grease... (the Red stuff) once I have gotten to the point of not being able to insert any more I switch to Mobile 1 75-140 gear oil.... I fill the remainder of the bearing with that .. then reassemble. I Force all this added lube through the ABS sensor hole.... It is slow go but as time has shown it does work. on a side note ...every time I have removed the bearings there has always been some leakadge inside the spindle area where Oil and grease have expanded outside the bearing... I also try to spin the unit as much as possible while repacking to remove as much air as possible.
