Question Front axle seal's
IDSTROKER
Blackfoot ID
Blackfoot ID
Ok les schwab replaced front ball joint's and all seal's. Now the passenger side axle seal is leaking oil out not a lot just a little bit enough to make the bottom side of the knukle oily. Is there a seal inside that got damage when they put the axle back in .:dunno
yes, and mine leaks, too.
IIRC, the seal comes out from the carrier side of the diff case.. that's why mine have been dribbling for 90,000 miles.
if you can get Schwabs' to replace it free, go for it. But if they balk, don't try to ram it down their throats.. make a deal with them.
IDSTROKER
Blackfoot ID
Blackfoot ID
Thank for the input. I did find a part number to fix the problem but I'll wait till summer. And do it my self WILL NEVER GO BACK TO SCHWAB AGAIN..... the part number is Dana/Spicer 36487.
I got the Ford ones in my tool box..
want those part numbers, too??
NevrKnow
Aiken,SC
I saw these seals on TV called SEALS-IT. Kind of a triple seal deal that racers use. Anyone used these? They are only like 30 bux or so. While I'm tearing mine apart to do the same thing I'm gonna get the best. I'm sure i only want to do this ONCE.
