fog lights
strokepower
Stroke=Power
Cook Station, Mo
Is there any way to make my fog lights come on while my parking lights are on but not my high/low beams....right now i just have my whole light thing out of the panal to make it work....but i seem to think i saw a thread about this?.....i was thinkin maybe i could just run my fog light wire to a toggle switch then i could just turn them on and off has a please...but i don't know if that will work.....anyway sorry if this doesn't make sense...any input is appreciated:thumbs
haulin8or
Hotlanta, GA
My 04 Excursion can run just parking and fog lamps without headlights. Not sure why it would be different on F250? :confused: I just turn the knob to the right one click and then pull out on the knob to run just p/lights & fogs and thats it. How does your switch work?
Red Monkey
Alabaster, AL
The link that 'drchris1024' provided does not have instructions for a 2001 SD. Does anyone know of a way to do this modification on an 01 model?
here's why RM, below is a list of the years that it will work on.
MODELS THAT IT DOES WORK ON
** 12/01 and Later builds of 2002 Model Year
** 2003 Model Year with 7.3 liter Powerstroke (aka the "Jace Variant")
** 2003 Model Year with 6.0 liter Powerstroke (aka the "BisonFarmer Variant")
** 2004 Model Year (F-250?) (aka the "Specularius Variant")
** 2005 Model Year (so far)
strokepower
Stroke=Power
Cook Station, Mo
Yeah i know that is how it is on the 04 superdutys.....cause our king ranch is that way....but my 03 xlt is not....you have to turn 2 clicks right then pull out....it won't let you pull out after the first click....which is what i want....
Here is the MOD you are looking for STEVE RACER FOG LIGHT MOD Also allows fogs light to be on when HI-beams are on.
On my 2001 it was even easier. Hope this helps.:cool:
yeah that is the one i remember but its not exactly what im looking for(from what i can tell)....even though if i can find a way to do what i want i will have that also....which is cool:thumbs thanks
as i recall the LIMIT on the switch has something to do w/ a
ramp clear bit of plastic (i dont recall if the ramp is accessable
externally to the switch or if the plastic ramp/limiter is inside
the switch).
the plastic stop (ramp/limit <- what ever you wanna call it)
needs to be trimmed so that you can pull the switch out
trackspeeder
Stone Crusher
North Branford CT
the switch).
Yes you need to trim the switch a little for it to work on the 01.
Dremel tool will make quick work of that.:thumbs
Now if I can remember the rest of the stuff to finish it.:dunno :D
