filler neck replacments?
jrisingmoon
Asheville, NC
trying to find a suitable replacement for my filler neck. No luck as yet, but will try junk yards soon. 84 E250 6.9 front tank. shot in the dark but better than a dead van...
I'd suggest transfer flow but I dont think they have a neck kit for an "E" series, and if they did you prolly wouldnt want to pay the ransom fee to get it.
What is the problem with your current filler neck?
BlueRidgeRunner
Ford Parts Guy
Roxboro/Cary, NC
A marine supply house should have a hose. The filler hoses on boats are similar. You will need to measure the ID of your old hose.
jrisingmoon
Asheville, NC
I had to cut it since it was practically melted onto the tank. Wish I didn't have to but too late now... MY FSV died and decided to change the return and supply hoses while everything was disconnected. In order to drop the tank I have to cut the neck. The same with the rear tank's neck but the rear tank was rusted out. I'll replace it when I get the $$$.
I'll check the marine supply houses. thanks.
Brad1103
