Fender Mod?
02stroker
Gratz, Pennsylvania
Heard a few mentions of a fender opening mod for the DIY air intakes. I looked in the WIKI, but didn't see anything. Can anybody tell me what it is and if it's worth doing ? Thanks.
Basically, if you have an enclosed filter set-up, it involves cutting a hole in the fender end of the filter housing, fabricating a foam sleeve that would go between the hole.. and a OEM hole in the driver side, inter-fender.
You'll be getting Outside Air thru the Zoodad, thru the snorkel AND from the fender well area as well.
I have it and Like It alot. Plenty of COOL(er) outside air
Poke [http://www.dieselpowerproducts.com] and check a pre made one out :dunno
