fan belt problems
94f450sd
certified nutjob
plymouth,ma
whats the correct belt for my 95?since my engine swap ive been replaceing the belt every 2 weeks or less.a couple times the belt was too long to fit so i had to get another one.after about a week they stretch and start squeeling.itll get so bad that i cant use my A/C without it squeeling.i replaced it the other night again and the new belt was once again way too long.i am now rideing around with 6 washers under the A/C compresser mounts.and its starting to squeel after 2 days again.nothing has changed in my accessory brackets or pullys.my tensioner is new.
if somebody has a part number that would be great.:thanks
Serpentine Belt
(Ford) F6TZ-8620-GA (1995-up 8 rib)
(Ford) F5TZ-8620-A (1994.5 7 rib)
(Napa) 25-081189 (1995-up 8 rib)
(Unknown) JK7-1201 (1994.5 7 rib)
(Goodyear Gatorback) 4071195 (1994.5 7 rib)
I think its 122 inches.
jharvey
Shutter Bug
Georgia
Check the alignment on ALL your pulleys, especially the vac pump and tensioner.
Please don't ask how I know you need to put a good eyeball on those pulleys every now and then :eek:
serpentine belts do NOT stretch...
replace the tensioner, and check the pulley alignment
