Factory cab light harness- on or two pieces?
W4RLR
High Tech Hillbilly
Sewanee, TN
I started looking over the harness I got from Powerstrokeshop.com. On Motoman's site, it looks like the harness is a two piece affair. I only have one harness in the box, and none of the connectors fit the light sockets. Am I missing a piece of the harness assembly or do you think I have the wrong harness?
Thanks!
Richard the kit I purchased was using OEM parts,the harness was all one piece which had five connectors that plugged into the base of each lamp assembly.
Cab Roof Lamp Harness; one end connected to the trucks main electrical harness in the kick panel and the rest to the lamp bases.
architect-builder
Jerome, Idaho
Thanks!
As said, it is one piece. This picture you are refering to is Motoman trying to show the difference from the non-clearance light harness and the clearance light harness.
Barrett
Some of the aftermarket cab roof lamp kits connect to the lamp bases with different connectors such as crimp-ons,the aftermarket kits take longer to install versus the OEM due to the wiring.
I haven't seen motomans tutorial yet so I don't know what he utilized.
Just the posting of motomans link is all that needs to be said:sweet
Thanks Barrett:cool:
W4RLR
High Tech Hillbilly
Sewanee, TN
Bob Baumann from The Powerstroke Shop contacted me, they sent me the wrong harness by mistake. Thanks for all the replies. :thanks
Since I don't own a 7/8 slugbuster, and can't see spending $40 for one to make 5 holes in the roof, does anyone have any other ideas? I do see a 7/8 hole saw that the package SAYS will cut metal, but it looks too much like a wood hole saw.
Once that is done and the lights are in, I tackle the job of the remote start/security system I ordered at the same time. I'll try to write an article on it for the WiKi.
Tbar
SDD STAFF/Moderator
Thats what was used on mine..........kinda messy. Just run a magnet all over the headliner to pick up the metal shavings before buttoning everything back up.
Tbar
