I need to change the oil in my Honda 4-wheelers. The manual calls for a oil with a SG or higher rating.
I have a case of Mobil Delvac 1300 Super that I would like to use. The 1300 rating is "API CJ-4, CI-4 PLUS, CI-4, CH-4, CF/SM, SL". I have tried to research this a little and found that the CF/SM stands for Commercial Fleet with a SM rating. Looking on the Mobil site they say "API SM quality oil, which is the latest API rating, is recommended where API SL, SJ, SH, SG were originally required". Does this mean I can run the 1300 Super in place of a SG rated oil?
The Delvac 1300 super does say "high performance diesel engine oil" but it also says "Mobil Delvac 1300 Super also meets the API SM specification for gasoline engines" and I guess SM exceeds SG?
Both my 4-wheelers have the Hondamatic-Fully automatic hydromechanical transmissions and I don't want to screw them up but if SM exceeds SG I can use up this oil that I have no other use for.
