ESOF
budtoh3zo
Little Smoky, Ab, Canada
well it buggered up finally went to use it and nothing. It locks the hubs in but not the transfer case up. wiring looks good any other ideas?
atk
Moderator
simcoe, ontario, canada
the electric motor on transfer case could be at fault. try taking it off and get someone to put truck in 4wd mode, while you watch the motor to see if it does anything...(make sure to set parking brake)sometimes they do get stuck from lack of using them. you also could check to see if motor is getting power. check the fuse.....hope this helps
