Vacuum pump runs, pulls vacuum and shuts off but neither hub engages. They do lock if I work them manually. The drive shaft to the 3rd member is engaged as well.
Just got the truck back from the shop after the wreck......they forgot the yellow orng seal when they replaced the unit bearing assy so I made them take it apart and install it. Outer seal is new and in place as well.
Still no luck. Any suggestions.....and no I don't want to get rid of ESOF.
Tbar
Tbar
