CKyle494
My '00 7.3L's engine was spinning slowly for the past couple months. I got 2 new batteries and it still spun over slowly. My uncle has a 7.3L in his Excursion and the starter spins his motor over VERY quickly. For the past couple of weeks, even after the truck had ran for a while, the motor would get to the point when shut off, the truck would crank slowly the first time for 3-4 seconds, shut it off and try it again and it would do better the second time and start. This morning I went to go to work and it cranked slowly, shut it back off and tried it again, no start. Tried it a 3rd time, again, no start, the 4th time I tried it, it cranked slowly and surged then just stopped all together. When I turn the key the starter doesn't engage or even try to engage, the lights on the dash seem fine and the none of the radio stuff has reset. I got out and could smell electrical burn smell. Is my starter TOAST? Or do you think it may just be my starter relay. I haven't had a chance to check it out because of work, but tomorrow morning I am off and hope to get a start on it, after it warms up some.... Thanks, Chris
