Electrical question
DieselPower
Diesel Lover
Memphis, TN
My 06 F350 rear passenger electrical window does not go up. I took the motor out, and the motor is OK. Is there a fuse somewhere that I can check?
Thank you.
Frankenstien
Frankestien
South Prairie Wa.
Does it function from the door itself?.... or not... is the malfunction only from the Drivers door switch?... if neither , work, first guess would be a broken wire at the door. or possibly a bad connector on the window motor.
Dogman
tampa,FL
Mine did that, Pull the master control on the drivers door. Test the switch with a tone meter. The master control is 99% of the problem.
