DTC.... 0478/0470
RenoF250
DungBeetle
California
If you are reading high I would think that means that your EBPV is stuck shut or your sensor is bad. If you have not lost power then I would say it is the sensor. I would replace the sensor if you want the EBPV to work properly. The elminator is for people that get rid of the EBPV.
kiarasue
The RamSmoker
Enumclaw, WA
EBP?
I haven'y had this problem yet but have read that you might just need to clean the soot out of the hole so the sensor can read again.
trickyricky23r
