Do I need a Massachusetts CDL?
dieselmac99
Diesel Christian
Lunenburg, MA
Hey fellas, I got a question. We got an Int'l 4700 lo-profile w/Altec crane. The problem is that it's got air-brakes. I've been driving it. No big deal. Kinda fun actually. It's got real high gears tho. redlines at around 58-60. Anyway. Do I need a CDL License or Permit? What's the difference? It's DOT, but so is everything else we got. Im on a class d now. Any help would be good thanks guys.
ponyexpress94
Diesel Power Junkie
Maryland
What is the Gross Vehicle Weight (GVW) Rating of the truck? Do you intend to pull a trailer behind this truck and if so what is the GVW of the trailer? This will help answer your question.
dieselmac99
Diesel Christian
Lunenburg, MA
I was told that the GVW was under the CDL requirement, and no trailers. But the big concern is the airbrakes.
94f450sd
certified nutjob
plymouth,ma
if the gvw is under 26000 (being a 4700 it should be under 26000) you dont need a cdl but you better have your dot physical card.
Zookie400
I WANNA GO FAST
wallingford, CT
you will absolutely at the very least need an air brake provision on your non cdl license. i would venture to say you will need a class b cdl.
94f450sd
certified nutjob
plymouth,ma
there is no air brake endorsement for regular class d license in MA.if its under 26000 pound gvw you dont need a cdl whether it has air or juice brakes.but as i said you better have the DOT medical card ON you at all times.if you dont have one just go to a walk in clinic and get it.its $75.00.
dieselmac99
Diesel Christian
Lunenburg, MA
Gee thanks guys. Thanks for the quick info. I have been checking around the MA RMV site, but it wasn't very clear. I already got the DOT Health Certificate, because I needed it to drive a GM 1-ton dump truck for my old job (landscaping). I carry it all the time. Thanks guys.:notworthy
Pm_guru
