Daytime running lights
HowieE
Princeton NJ
Just noticed my daytime running lights are out. The fuse is good. Anyone know the location of any relay or resistive load that may be in the circuit?
The Ford manual indicates the daytime lights are th normal bulb on lower voltage and my headlights work so I assume it is not a bulb issue.
If the problem (Hopefully) turns out to be the bulbs ? You might wana look into LEDs as replacements. VERY low amp draw, purdy much last forever.
One source to Check'm out is: SUPER BRIGHT LEDS home
HowieE
Princeton NJ
Well after getting a wiring diagram, poking around under the hood to locate parts, and calling the Ford dealer I now find out that Day Time Running Lights are not stock on Excursions. That may be why mine don't work. The parts aren't there.
Ford describes the operation in the owners manual, show are the components on the wiring diagram, and some of the wiring is there.
