dana 60 front axle swap
IDSTROKER
Blackfoot ID
Blackfoot ID
I did the same swap in my 1996 F250 it was pretty easy did it my self in 4 hours. The dana 60 was out of a 1997 F350 all suspention brake's etc are all the same.
IDSTROKER
Blackfoot ID
Blackfoot ID
Everything should go in just fine only thing that i did that you might is the front driveline that is on the IFS has a u-joint on each end. you want to get a driveline out of a F350 it has a u-joint on 1 end and constant volcity joint on the other. If you don't it will probably viberate and be noise.
IDSTROKER
Blackfoot ID
Blackfoot ID
Well Your good to go It's really not that bad to do just get some good jack stand and lift the whole front of truck off the ground. And start turning wenches.
7.3turbodiesel
Terrace B.C. Canada
I took the diff cover off and i found some water in their. whats the best way to clean inside their? Do i use brake clean to wash it out and then just refill it back up with 80/90 gear oil? Or is their something i put in their before i put the gear oil back in?
