CrankCase Modification
ranaumo
Diesel Junkie
LA - Lower Alabama, part of FL
Hi All,
I did my mod today and wanted to mention a point of difference.
On the 95 PSD's the cast part has a reducer built in. Unless you have the updated air hoses, the 3" metal pipe will not work (that's the bad news).
The good news is the fitting that bleeds into the cast part is held in by silicone and a phillips screw. I used a handsaw to cut both the top and bottom, them slipped in a piece of 3/8 hose. Covered it with silicone, then ran a screw, washer on both ends and a nut to lock down the opening. Then covered the screw head with more silicone (overkill, I know) and let it set.
Putting it all back together is pretty much teh same afterwards.
Hope this helps somebody.
Ron
