HorseHauler
I hope this is appropriate to be here.
I have a '97 which I am doing a vegetable oil conversion on. Before I can put everything back together (including air intake and turbo) I need to get the coolant plug that is below the upper radiator hose out and put in a special thermostat for use with the new system. It has a sqare recessed place in the plug. A 1/4 drive is too small, a 3/8 is too big. I've ground down two 3/8 drives to fit but broken both. Where can I find this?
