Cooland filter
Ironmerganser
Ironmerganser
Omaha, NE
I also purchased the coolant filter today. Once that is installed and I have run it through a few filters, should I do a coolant flush and put in new coolant or should I just run with it? I have 73k on the original coolant now.
And that is suppose to be "COOLANT" not cooland........fat finger syndrome......
Thanks!!
id run the coolant filter <it will probably plug the 1st one pretty
quick...my 1st one was plugged w/in 1000 miles or so, and
even my 2nd one plugged w/in about 2 or 3k>...run the filters for
a bit <get that casting out> and then do a flush if you think you
really need it.
while your doin' all this check that lower hose...make sure its
not gashed by the steering control arm like mine was.
Yep, that would be a good time to change out the lower hose and put in new
"COOLANT".:thumbs
Northeast Texas
on my second cartridge... first one ran 30k, cut it open and was surprised it was not to full of gunk
then as luck would have it she got a brandnew raditior a few months later and a new fill of the gold.
Tbar
SDD STAFF/Moderator
My thoughts..................
Flush the !@#$ out of it now. Why pay for additional filters if you don't have to.
I pulled my thermostat.........connected the garden hose..........and let the engine run for 15-20 minutes(non pc way).
FWIW..........as long as you can feel heat coming from the return side hose on the filter the thing is still good to go.
Tbar
Tbar
i agree at least in part...you gotta get that casting crap outta
there...'specially w/ the issues im hearing about the oil cooler plug-ups.
the filter add-on is easier than flushing the coolant...and as deterimination
of when the filter is FULL (or plugged) a light touch to the filter
will determin if its HOT or cool to the touch....cool means its FULL &
needs to be changed.
Ironmerganser
Ironmerganser
Omaha, NE
Well.....got it all installed. Lost a little coolant on the driveway, but nothing big.
Thanks for the help guys!!!
dont know if youre running a 6.0 or 7.3 <hint>...but the GOLD
coolant can be had @ Autozone (only place ive EVER been able
to find it)...under the BRAND NAME: ZEREX in a GOLD BOTTLE labled
G-05 (it meets the spec that ford idenifies in the owners man.)
