Why would you change out those lines? Where did you find that information?
They are perfecetly fine for B100.
I have been running B100 in my 97 since August of 2005 and NO PROBLEMS.
Stock filter is fine.
As for cleaning out, thats a WHOLE LOT OF WORK dropping tanks and such.
I would ramp up, start with B20 for a tank or two, then B50 for a tank then B75 for a tank and then B100. Carry a spare filter, vinyl gloves, rags and tools to change the filter and your set to go.
You could also consider adding a filter. I use one that I can reach under the bed side and take off by hand and not even see it. Dump it out put it back on and go. This is on my 96 and I am speaking from experience. 6 clogs in 20 miles a few weeks ago! But the truck had winter fuel in it from 2005. Dont drive it much. The 97 however has never plugged on me and I have run a bunch of HOMEMADE B100 through it.
The only thing of concern other than a filter clogging may be a fuel pump on the verg of going anyway or if the short lines from the filter cansiter down low are weak and brittle from age and heat.
Rick H...
