Clutch replacement - think I can DIY?
HorseHauler
Kentucky
Hey all,
Dads trucks clutch is going out, about time since we're pretty sure its the original. I'm 19 years old, learning all I can about maintaining vehicles. I bought the Mercedes in my sig because a diesel truck was too expensive, and I wanted something that would help me learn about working on cars. I have very little automotive experience, but I read a lot and can apply what I learn in the garage without a problem most of the time. I've helped drop a transmission in a 99 Superduty, but it was an auto and pretty basic flywheel replacement.
So whatcha think? I have spring break here in a few weeks. If I read up on it, and give myself the whole week, think I can get a new clutch in (and any other necessary replacements, while I'm in there)? We have a good mechanic that would do it otherwise, so if worse comes to worse we could just let AAA haul it to him. I figure I'll need to rent a clutch centering tool and a transmission jack, other than that we hopefully have all the tools and a garage to work in.
Any recommended articles? Looks like the WIKI doesn't have anything, or I just don't know how to use it properly. I'll look into a higher performance clutch, but Dad probably just wants a basic clutch that will last a while. He's not into high performance, I'm still trying to get him to let me straightpipe the exhaust.
Patrick Feeley
Tehachapi, CA
This is for a SD, but will help regardless: "Luk Aftermarket Clutch Upgrade". You can do this if you've done an auto since it is really straightforward. Get a SingleMass Flywheel Conversion Kit from Luk or SouthBend (I prefer the SBC). It'll come with the cenetering tool and throwout bearing (my SBC did). Cheers!
Go for it HorseHauler. That is how you learn. The tranny is very heavy and you will not be able to muscle it out and back in. Use a GOOD floor jack or a transmission jack (rent one) to save you lots of sweat and time. Good Luck on your project. Two days tops.
Dave :)
strokin'_tatsch
death row inmate #7
Austin, Texas
yeah you can definitely do it. i'm 16 yrs. old and i just did mine last month in a shop with dirt floors after it rained so it was all mud. i put in the LUK conversion flywheel and clutch. it came with the throwout bearind and the alignment tool. it cost $720. very easy to do. would have been easier if the transmition jack i was using wouldn't have broke while i was putting the tranny back it so me and 2 other guys muscled it in there
