chips
strokin'_tatsch
death row inmate #7
Austin, Texas
this summer i will be getting a chip for my truck. my first question is what is the best chip i can buy for a OBS truck? my second question is what power profiles should i get? i want a high idle and a stock, but what profile is best for towing? and what other profiles would be good to have?
hheynow
Señor Aceite de Soja
Northern California
My DP-Tuner is 4 pos
stock/40hp econo/80hp tow/high idle
I rarely use the 80hp.
strokin'_tatsch
death row inmate #7
Austin, Texas
would a 40hp program be better for pulling heavy loads? what economy profile would be the best? i know i want a 140hp profile also
Zookie400
I WANNA GO FAST
wallingford, CT
79broncoidi had problems with his on 140, because the heui pump could not keep up. it would bog out if he floored it.
strokin'_tatsch
death row inmate #7
Austin, Texas
oh... well i plan on doing a lot of things this summer such as injectors. so do you think that i might need to buy a better fuel system?
DOC-MX
FOREIGN MEMBER
Celaya, Gto, MX
DP tunner or Tony Wildman are both top notch. :thumbs Just call them and ask what are you thinking about your planns, OK?, thats the great think about the chips (customized to each one)
Russ
Found On Russ' Drive
New Brighton PA
Talk to Tony Total Diesel Performance Home Page
He's the one you want. I use the 40 tow for everyday driving. 80 when that little extra is called for, and I don't use the High Setting very often, mostly 'cuz I can tell the tranny doesn't like the extra power. I towed with the chip for the fisrt time last weekend. 40 is good, 80 is a bit much(have to watch egt's) I also have baby swamps and Tony's chip REALLY woke them up.
strokin'_tatsch
death row inmate #7
Austin, Texas
dang. his chips are a tad expensive. but i'm sure if y'all pick him then i won't regret spending the extra money on his chip over the DP-Tuner chip
