hheynow
Señor Aceite de Soja
Since my DP-Tuner chip was installed the wait to start light does not come on when I start it in the morning. Any ideas? Otherwise, it functions perfectly and starts right up.
I dont know what code Tony burned my chip for, but my GP's cycle much shorter now than when I was stock.94f450sd said:the 95s WTS and glow plugs will come on all the time for the same length of time unless you have put the TDE1 PCM in it or had the chip burnt for the TDE1 PCM.with the TDE1 the glow plugs only come on under 50 degrees and when needed
