changing o rings on ipr
rp95f350
any idea size wrench or socket required? will a wrench even work?
I did mine with a 1&1/8" wrench just used the box end as long as you have one that is slightly offset as in not a straight wrench you will be fine. provided a bit of patients is in your personality because it involves quite a few small turns to get it on and off with the open end wrench.
