changing fan blade question
bears4x4
grease monkey
katy texas
i havent done it yet but is it possible to change out the engine fan blade with out R&R the radiator??
mp18d
Truckee, CA
Thanks
JL
Thanks for posting that tool info!! :clap::clap: Been looking for those dumb things for a couple days, never could get good part #'s
Mike
IHC Power
STOCK STROKE
Walpole Mass
Viscous fan
Hey man that's a sweet rig you got there, just ordered the same lift kit for my 01 350 psd. Just so you know the tool kit for the fan is not necassary if you have an arm hammer, the water pump threads are reversed(remember that) the radaitor shroud is two pieces when you take the (2) 8mm bolts out at top. The top half pulls straight up. Wack the ridge of the nut with the air hammer and walla, the fan will spin off, then tighten new one with a huge adjustable wrench. Good luck and keep trucking.
dboyw
Lancaster, PA
Check AdvanceAuto. They have a loan-a-tool of the fan wrenches. Used them for my water pump replacement.
