noticed some blow by coming out of the dip stick tube when i changed my oil the other day. im thinking the CCV is getting clogged. its no blowing by bad. just the first time ive been able to visually see it.
Could be clogged, but I doubt it. It is absolutely impossible to stop any and all blowby, some is gonna be there and is fine, wouldn't worry about it unless there is excessive pressure. Signals restricted vent like you said, or a compression leak....doubt its that or your post would have some explitives in it -mad -mad
Have you thought about the good ole CCV mod? You will have a cleaner engine bay and charge air cooler plus up to 15hp has been recorded because of the negetive crank case pressure. Check it out.
