Howdy All,
I looked on Wiki but didn't find anything on this. I would like opinions / suggestions for installing carpet. I found a nice gray marine grade carpet at Lowe's for $4.41 a cubic yard. I know there are places to order molded carpets, but I am under the impression the marine grade will hold up a little better with kids, dirt, stains, and so on. I have seen where some of y'all have put down noise barrier, will thick carpet padding work, or are there issues with it that will cause headaches?
Also I am finally fixing my headliner, have any of y'all used a radiant barrier on the inside of the roof? Unless y'all say differently I was planning on putting the radiant barrier on the inside and the painting the roof white. I am measuring about 6 inches from the edge of the roof inside this is what I am going to paint white. All you will see is the stock color from the ground.
And finally, just to make sure I am using WIKI right, just like other search engines, type in your topic in the search box right? I have had success with other items.
Thanks for your time and suggestions,
Craig
Craig
