Bully Dog Power Pup
CSIPSD
Bend, OR
Nope, trust me I have seen the software and the readings the equt can find...
01SMOKINSD
Wakeman, ohio
From what I was told none of the chips or programmers are undetectable, wether they have a stock setting or not. I set mine back to stock and they could still tell that It had been in there. Just trying to give ya a heads up. I know that some dealers dont care if you put a chip in it and then bring it back for warrenty, and then again some are real sticklers about, and wont touch the truck if its had a chip or programmer in it. In the end its your call, you may want to check and see where your dealer stand with warrenties and modified trucks. Good luck.
scotty7751
Big Daddy
NORTH Dallas, Tx
i like mine it easy to install and great if i had known more about tuning i would have gona with a TWEECER which you plug in laptop and have fun but to advanced.
CSIPSD
Bend, OR
You pull that bully dog and install a chip and you will be at about 350 with that set up... I am at 363 with mine and water-meth
Jriltex
