If the calipers are sticking, I would ditch gthe rebuilding and just replace them with aftermarket parts. It's way easier and you get a warranty. one obvious way to tell if a caliper is dragging is to check both sides, if one wheel rools easier than the other, then squeeze the piston back as mentioned earlier, and try again. If they now spin the same, you got a bad caliper on the "slow" side
