Brake controller
HowieE
Princeton NJ
What brake controller is recommended for the 2004 Excursion and a tri axle trailer?
I have always used a Jordan mechanical but not sure if it can be used with movable pedals.
6LMonster
Wake Forest, NC
The Prodigy from Tekonsha will get you what you need. Great controller. Plug it in and tow. It is good for up to 4 axles.
fordtrucker4life!
I work with waste
SE Michigan
I have a draw tite very basic actuator. I goes up to 3 axles. On most Fords there is a plug under the dash to plug in a controller and go. The wireing is already installed to the rear (if it has a 7 pin plug).
RoyBoy
Diesel Dork
central WI
I have the Prodigy as well, but from what I heard, the Jordan is pretty good, If I were you, I'd try to make it work with your pedals :sweet
