BOOST question
Hoss 350
My GSP, Dutch
Spokane, WA
jopes said:
before I did anything to my stock 01, I could not get any more than 15 psi. now I have inched up to 20-21. would this mean I could have a intake leak?
With just a 10K mod, you are probably about right. 15 psi is a little low for stock, it is usually about 17psi.
jopes
Wyoming
What could cause it to be a little low? it is just about to turn 70k
Check all your intercooler boots and intake boots, you might have a leak. Make sure your boost tubing and gauge fittings are tight also.
jopes
Wyoming
I will have to research how to check for leaks. I always thought it was pretty weak in the power department when we bought it.
Pm_guru
