JOAT
I Found Nemo!
Well, I succumbed to the hype a week ago and decided to try the BLUE MIRACLE CPS in my truck. Had 80k on the current one, so wanted to get a spare anyway. $105 and a few bandaids later, and I was running in the Blue Zone.
After a week and about 1000 miles, I've noticed no reduction in body odor and my "male pattern baldness" is not reversing.-mad So much for miracle cures.
Ok, so as far as my truck goes, after I installed the CPS, idle seemed smoother and there was a bit less injector clatter. However, those are things that seem to come and go with my truck, and sure enough by the end of the week the sounds were back to normal.
As to power, there is a fairly long grade I travel daily, and on the first day, seemed to have more power going up, and more compression braking going down. The rest of the days seemed more normal, so likely wind was a factor more than the CPS.
Fuel economy is harder to judge overall as I run WVO on the highway. I have a top fill WVO tank in the bed however, so that mileage I can measure accurately. MY WVO highway only mileage 2 fills prior to the CPS was 22.2 and 23.23 mpg (again, highway only). Using the same techniques, the 2 fills after the Blue CPS were 22.76 and 22.7, so no real improvement yet. Dang, another miracle MPG improver that didn't work for me. I should be getting 1000 MPG by now with all this stuff I've tried
The Blue CPS does have a stronger magnet by far, so maybe it will be more accurate and reliable overall. I don't know about longevity tho, as the IH guy knew the part number from memory. That would seem to indicate they sell quite a few of them.
Anyway, it is not any worse than the standard CPS, so I will probably stay Blue from here out unless problems arise. I'll get in some #2 only runs eventually and see how they compare. Will post if anything changes.
