Block heater
Mystic
Peabody
How much does it cost to plug the truck in for say 8 hours over night? I am talking about on the electric bill.
Scar13
Little elm, tx
If I remember correctly a gooood amount as it pulls alot of electricty. Exacts I cant remember...
but its alot! 1000 watts. that sound correct, Ill look for that linky
Scar13
Little elm, tx
Ahh it is 1000 watts
"The electricity to run the block heater probably costs you about ten cents an hour. So 3 hours is thirty cents. But over night of 10 hours is a dollar, and if you leave it plugged in all the time, that's about $2.40 per day or $72 per month. It adds up fast."
Quated from another site, but I thought it was more like 30 cents a hour??
Shrug, its 1000 watts so where ever you are and your electricity is, would be your cost!
1000 watts = 1 KW. Check with your utility company what you pay for a killowatt but I doubt its much over 15 cents. So, its 15 cents an hour or roughly 1.20 a night (8 hours) and if you are concerned about spending a buck a night then you can purchase a timer to turn it on 4 hours before you plan to start in each morning.
jharvey
Shutter Bug
Georgia
Get you a timer like Mike said, make sure it's rated for 15 amps. Set it to come on about 3-4 hours before you leave and you're good to go.
Oh don't forget to unplug it before you drive off..........don't ask :rolleyes:
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
i did testing on mine with a special meter... cant find my exact spec sheet i made up ,will look for it later..... but if i remeber correctly it was only about .09 cents an hour if that. i'll look for my paper later and report back.
Neal
Mystic
Peabody
Ya it was because someone told me its $3 a night which I thought was alot, I should get a timer for it maybe next time I am at the store.
