dboyw
Couple questions regarding the block heater.
I bought the marine plug, can't remember name now, and I was going the put on front of the truck behind the license plate. Now I think I want to put it in the rear of the truck. I am going to buy a holder that you put a seven pin trailer plug into and use it the the new heater plug.
OK, questions:
What gauge wire do I need for the plug to run to the rear of the truck?
Should I cut the original plug and wire off close to the plug or close to the heater part?
Has anyone ever put two plugs on a truck? One in front and one in rear. I thought of doing this but is there really any advantage to doing this?
Would this LED http://www.radioshack.com/product/i...2058&kwCatId=2032058&kw=led&parentPage=search
work to verify that power has been established when plugged in to the truck?
Thanks for the help. And if there is anything else you think I should know, please tell me. Thanks
OK, questions:
