Biggest tires i can go
clintusaf
Clint
Bossier City
Heys guys,
new to the site and fixin to purchase a 02' f350 4x4 lariat crewcab long bed w/ a leveling kit. it has 285/70 r16's on it now and i want to put some more aggressive tires on it and fill out the wheel well nicely but not have any rubbing issues. what would be the biggest i can go, and do ya'll have any suggestions of what brand to put on it?
roger2003
Milwaukee,WI
I think that 31's will fill up that wheel well nicely, as far as the tires Toyo or super swampers. It depends on your tire needs and your personal opinion.
clintusaf
Clint
Bossier City
i looked at a tire calculator and 285/70r16 is actually a 32" tall tire. the truck with the leveling kit has a lot of room to fill in the wheel wells. i was thinking 315/75 r16's (35's) would be nice, but they might have rubbing issues. does any one on here run this size tire with the same setup? maybe the 305/70s(33's) maybe a better chioce.
285/75R16's or 305/70R16's are usually the biggest you can cram in there without trimming, lifting, etc.
the 305's are as wide as the stock wheel is rated to handle
BIG DUTY
F-250 Care Taker
Traverse City, MI
I run 315 75 16 on stock wheels without any major problems. My biggest complaint is the tires rubbing the front leaf spring at full turn. This isnt a major problem you just lose a small amount of turning. I have a 2.5" front leveling kit from Summit Racing and a rear add a leaf. My truck is a 2000 F-250 Ext cab 4x4
clintusaf
Clint
Bossier City
Cool. That's what I was wanting to know. Are there any major problems that would cause longterm effects? Frontend wearing out? Did you change the gearing for your tranny?
