Best Turbo for 7.3L????
what turbo to get depends heavily upon where you want to end up power wise and what you do with the truck. Is it a daily driver, primarily a tow rig, or sled pull truck? When you combine use with power then you can get an idea of the turbo that would fit, also a budget helps a bit also.
sagebel
Stock? Pfft!
Albuquerque, NM
With the mods in your sig a GTP 38r would work well. Anything bigger and you will need some fuel to spin it.
