Bad Turbo?
bbressler
Happy, TX
While installing my DIY intake, I looked down at my turbo, and noticed that the fins aren't uniform in spacing. I figured they are probably meant to all be a certain distance apart from each other. I snapped a picture, can someone tell me if I need to replace that thing?
Also, there's a little tube inside the intake, what's that do? It's visible in the picture as well.
Thanks
Nope, your compressor wheel is supposed to have unevenly spaced vanes, your's is fine. That tube should be your cranck case vent, look under the intake right where it goes in, it should be above the valve cover and this is where it pulls engine vapors for the CCV.
