BigSilverHD
So I raised the front end on my truck and did the wiggle test on the tires to see if they move, and sure enough the front pass. tire had about an 1/2" wiggle in and out. So I tore apart the hub assembly and was down to just the knuckle and the axel.
So after all that what I need to know is how much play should there be when you grab the end of the axel move it up and down?
any help would be great as I am needing to get my truck back up and running and i dont want to put the hub assembly back together and find that i really needed somthing else as well.
