ats housing and a WW will it beifit to use both? i was just going to buy the ats housing but figured for 77 why not put a ww on...would the ww with ats housing be a better option than just going with the housing? i know they both eleminate the flutter just asking in a performance aspect as dennis from itp diesel told me not to got with a garret bb turbo unless i did injectors....
""With just a chip for power adder, I'm not sure you'd be tickled with spending $1600+ on a BB turbo for what you get. If you think you'll be doing some injectors down the road...then it would be more worth the money to upgrade the turbo. If you think you'll be staying with stock injectors, put an ATS housing on your stock turbo and use the rest of the money for other mods (real fuel system setup instead of just a shim for instance).""
