Anyone make a 1" lift block for the rear of an F350?
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
I put on a Fabtech 3.5" leveling kit on my 2001 F350 4x4 and it sits about 0.5-0.75" higher in the front. The rear is still stock so I'd like to raise the rear up an inch or so to level it out. Does anyone make a block like this?
patrickc
Ontario, Canada
Superlift makes a block kits starting at 1.5" Skyjacker makes blocks also starting at 2"
Another option is to replace the factory block (if you have one, mine did it was 3 3/4" tall) with a 5" +/- block rather than stacking blocks. I had the same problem with mine when I added the 2" pro-comp shackle and hanger kit. I ended up removing the factory block and putting in a 5.5" block to level it out.
drchris1024
SDD Security
on a river in Georgia
Donohoe Racing makes all kinds (lengths). I believe you have a 4" block and I know they have a 5" block. I have a 5 1/2" on mine by them.
f100cleveland
Southern Minnesota
I'll have to check into the price difference between a 5-5 1/2" block vs a 1-1 1/2" add in block. I'll let ya know what I decide. Thanks
