anti freeze everywhere
Diesel Kinevel
97 Stroker
Frederick Co. MD
on the way home from work i got a faint smell of antifreeze then smoke started coming through the dash. I managed to make it to the drive way i shut it off popped the hood and everything was covered. it sounded like air was seeping out from one of the injector ports i have never encountered anything like this please help
First thing to check is the weep hole on the water pump. When the pump goes out coolant comes out the little hole on the bottom of the pump.
oi8228oi
another 99
yup most likly thing.... if it is the water pump you should try installing a coolant filter while the pump is brand new (much easier to get the plug out). then you can tell us how many miles you get out of a pump when its got a filter....
Diesel Kinevel
97 Stroker
Frederick Co. MD
it was a coolant line goin into the block I couldnt see it through all the steam and such thanks for the help im gonna watch my water pump now that you mentioned it. ive been having troubles with coolant lines i dunno why.
thanks guys
