Another stupid ?
dieseldork
dieseldork
ca
With the mods in my sig, What would you guess my hp #s would be? The controller is set at the highest setting..........:dunno Let er rip!!!!!!!!!
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
With stock split shots, stock HPOP & a programmer, I'll guess 325 hp. :dunno
Honestly, you are about 30 horse maybe 40 horse more than stock trim. You have done an excellent job of setting yourself up for future HP adding mods but the mods you have done arent big gainers. The 01 model was what... 250 hp (correct my number if it is wrong) at the flywheel? So you were probably 205-210 at the wheels stock, now you might be 235 give or take at the wheels.
Add a fuel system, throw in some injectors and get a custom burned chip or PCM and you will easily be 350+ at the wheels.
Just my two cents.
roosterdiesel
Earl needs B100
Amarillo,TX
My '01 ZF6 says 275hp on the valve cover.
With an Edge Evolution(which was known for more power than the Superchips), shimmed FPR, DIY intake, ATS compressor housing and 4" exhaust I dynoed at 304hp on a Dynojet.
